Results 1 to 11 of 11
  1. #1
    Author of This Thread
    Junior Member
    SH EMT is offline
    Joined May 2010
    ny
    Whelen HHS2200 siren tones help
    I just had an HHS2200 installed in my car and the only siren tones it has at the moment are manual and wail. The installer told me that the only way to get the other tones (yelp and piercer) is to hook it to the horn ring. Is this true, and if it is, is there some other way to go about hooking it up without using the horn ring to get
    the additional tones (perhaps a momentary switch) ?
  2. #2
    Moderator
    Communications
    EMT
    Volunteer Fire/EMT
    Fluffy126577 is offline
    Joined May 2010
    Findlay, OH
    If you had this installed I hope it was not done by a professional because this siren is programmed via computer and any installer worth his weight should know that.
    http://www.whelen.com/install/142/14207.pdf
    I hope this helps.
    "Never be afraid to try something new. Remember that a lone amateur built the ark. A group of professionals built the Titanic.“
  3. #3
    Veteran
    Collector
    Communications
    SireLite is offline
    Joined May 2010
    Conwy, Wales, GB
    To my knowledge every HHS2200 comes with programing software. If you are the one that bought the siren and the installer installed it for you. He should of given you the software disk so you can program it to your desired setting. The software allows you to program the hss2200 to which ever tone on any button you desire.
    By the sounds of it. The installer you used isn't very intelligent as has clearly not read the instructions properly on how to install and program the unit.
    Jim - SireLite Thinking outside the box.
  4. #4
    Junior Member
    SH EMT is offline
    Joined May 2010
    ny
    Thanks for your help. I will bring it back and have him reprogram it. He left 3 buttons blank so there's no shortage of switches.
  5. #5
    Veteran
    Law Enforcement
    Communications
    Volunteer Fire/EMT
    Pimp is offline
    Joined May 2010
    Louisiana
    All of these tones are possible out of the HHS2200:
  6. #6
    Junior Member
    SH EMT is offline
    Joined May 2010
    ny
    Is it possible to have 1 switch wail, another for yelp, and a third for piercer. From what the installation instructions seem to say I don't see that I can.
  7. #7
    Veteran
    Collector
    Communications
    SireLite is offline
    Joined May 2010
    Conwy, Wales, GB
    If you wanted you could have all 9 buttons as siren tones. You can't have the top 3. While your there get your software cd back.
  8. #8
    Veteran
    VolEms is offline
    Joined May 2010
    NY, USA
    The way I program them the top 3 for lights. The bottom 9 for sirens. HF,Manual,air horn,wail,yelp,peircer,mech,power call,and horn/siren.They are very easy to program.
  9. #9
    Junior Member
    Fire/EMT
    firemedic12 is offline
    Joined April 2011
    TX
    Tho I only have an hhs2100 mine has a hf button that you activate than i push the manual button to switch thru my siren tones may help may not but their is my .02
  10. #10
    EMT
    Hobbyist
    yakomo is offline
    Joined June 2010
    NY
    You can program it yourself. I programmed the HHS2200 top left button H/F, the to top middle Manual, and the rest are all sirens/air horn.
  11. #11
    Junior Member
    SH EMT is offline
    Joined May 2010
    ny
    Thanks for all your help! I'm going back Wednesday morning and hopefully they will reprogram it for me. If they don't do it I already called Whelen and they are sending me a copy of the programming software. Is there a separate cable that I need to connect the HHS2200 to my computer?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Back to top
