12 Volt 5 Amp Power Supply With Mini Light Bar That Draws 6 Amps
Minnesota
Could be a few things but bottom line, get something bigger. It may not be able to start it. If it does it should have over current protection and shut down. Being a generic supply, it would likely overheat and be a hazard.
In general, a supply with at least 30% more capacity then you need is a good idea.
Reactions: Jim1348
C17LVFD
Harrisburg, PA
I’ve seen some computer power supplies converted before, even done one myself… 500 watts is a pretty standard baseline on those, and would be a cheap way to run something with overage coverage as Jennifer mentioned above.
Seth
Reactions: Sparky_911
Ragnarok
