Apollo head question
rescue567
234
Plains Pa.
Are the Apollo 100 and 200 heads the same as the heads in the Apollo 800 ? Talking about the dual color heads. Was wondering if they can be switched from the smaller units into the bigger ones. Thanks in advance!!
Dave F
Moderator
Sep 13, 2015
1,343
Berks County, PA
Im sure our resident Feniex guru Nic from FEVER will be along at some point to answer this, however Ill ask for clarification: are you referring to the heads themselves, or the newer "F12" version vs the older "F6"?
rescue567
234
Plains Pa.
I am thinking they are the F12 heads. They have the frosted hole glass diffusers on them. The 800 has a build date of 2014. Not sure on the others. Would have to check. Thanks for your help !!
bullfrog4ever
336
Indiana
Are they the same type heads, yes.
Are they interchangeable, no.
The heads in the Apollo 100/200 have the internal flasher in them, they are the same heads as the surface mounts. Apollo 400/600/800 have dummy heads with a flasher attached to them.
All of their 100/200 style lights are built with surface mount lights that have the internal flashers. All of their 400 and up lights are all dummy modules attached to a flasher.
Hope this helps!!
Carlos SpicyWeiner
May 3, 2012
5,233
Lakeland, Florida
Correct. All 100, 200, 1x, 2x have the smart heads that are essentially the f6 t6
Everything bigger has dummy heads
Reactions: Dave F
RetLt2020
