Pegasus Takedown Patterns
hfdemt4095
492
Holliston ma
This may be the wrong section, but is there a way to change the pattern for the takedowns on the Pegasus? Also if a switch around the placement of the takedowns, do they need to be plugged into a certain plug on the bar?
Tom@Feniex
54
Austin, Texas
Unfortunately, there's only one pattern for the Pegasus takedown. It's the standard single slow flash pattern.
You shouldn't have any issues with the t/d placement from the original spot.
Carlos SpicyWeiner
May 3, 2012
5,233
Lakeland, Florida
But he would need to have the takedowns reprogrammed them if he does not plug them into the same place on the 10x, right?
HF.... you can move them around freely on the bar, however, they should stay in the same spot on the flasher (unless I'm mistaken).  If not their location will have to be reprogramed. Would be easier to just leave them plugged on the board but move their location across the bar to your desired choices.
Reactions: Tom@Feniex
hfdemt4095
492
Holliston ma
I was able to change the drivers side relatively just by moving modules.. Passenger side I had to switch connectors between td and the other module then switch position on the motherboard (mainly because of my laziness- I didn't feel like cutting all the zip ties)
Is there a way to reprogram the module itself? I thought they were all "dummy" heads set to steady burn
**i also noticed that there was a green led flashing on the board which I have never moticed before.. Is that because it had 12v running to it without the warning mode activated?
Tom@Feniex
54
Austin, Texas
Yes, Fever is correct. To avoid reprogramming the board I recommend relocating the T/D and its wires. Unless you have about 15-30 minutes to spare to go  through the T/D reprogramming steps. Hope this helps.
hfdemt4095
492
Holliston ma
Could you either link the steps to re programming them or shoot me a pm and let me know how to do so?
Carlos SpicyWeiner
May 3, 2012
5,233
Lakeland, Florida
I'll let Tom answer that but I have always found it quicker to reroute cables
Hmood
