Whelen Freedom Lens Kit question
ffjwhite
Bombay, NY
Well I am trying to order a new lens kit for a customer of mine, and I can not find a freedom kit online, just the 9m. Now are they the same as the freedom. I would think so but I just wanted to make sure before I order otherwise I am out $180. I cant find specs on it and the only difference I can find is that the kit numbers are different. Would like to have this figured out before Monday. Also does anyone have the measurements for the standard lengths? Thanks for the help in advance.
wilsonbr90
1,427
Corning, New York
The front and rear lenses will fit but I would take encapsulated measurements as they are different I believe. 9m should be narrower than a freedom.
emtanderson51
3,795
USA Massachusetts
Y
You need to order an Ultra kit. The endcaps are wider than the 9M. They are 9Ulenkt1/2/3 depending on how many cuts you need. Attachments are right here. You need this for any lens order:
https://www.wechome.com/main/download.aspx?file=Bulletins/LensRehabprogram.pdf
cmoore77
